2006 Factory Sirius tuner location??? Help!
Old Nov 21, 2007 | 03:46 AM
2006RamCrazy's Avatar
2006RamCrazy
Default 2006 Factory Sirius tuner location??? Help!
Does anyone know where the factory mounts the Sirius tuner or reciever in the 2006 Ram Quad?
My local dealer won't tell me and I cannot find it...
I want to remove the factory installed Siriustuner, sell itand use the Factory installed Sirius antenna to install a plug and play Sirius. I am currently paying for several radios in several vehicles.... If i install a plug and play reciever in my Ram then I can swap it between my work and personal vehicles and only need one Sirius radio...
Thanks for your time
http://i16.photobucket.com/albums/b4...y/MVC-001F.jpg
Old Nov 21, 2007 | 07:34 AM
djr04's Avatar
djr04
Default RE: 2006 Factory Sirius tuner location??? Help!
either behind glove box or underneath passenger rear seat. If it's a reg cab look under the center seat. [/align]
Old Nov 21, 2007 | 09:45 AM
Parts/Service's Avatar
Parts/Service
ORIGINAL: 2006RamCrazy
Thats what gives dealers a bad name. Look me up if you ever need advice.
See this post for helpful info on this topic>>> https://dodgeforum.com/m_1050383/tm.htm
Old Nov 21, 2007 | 09:53 AM
2006RamCrazy
ORIGINAL: djr04
Thanks for the reply however I have already removed the gove box door and looked above, behind and below....it's not there...
Underneath the passenger seat is the trucks jack so it isn't there.
I have the Front Bucket seat option package so I don't have a center seat....the center console goes all the way to the floor...I didn't find it in there either..... (I do have a Quad Cab)
It baffles me as to where it is.....This 2006 is my 5th Ram and I've owned Chrysler Products for the last 14 years so I've alwaysfound Chryslers hiding spots pretty quickly until now.....
Thanks for your help
Jesse
[IMG]local://upfiles/78648/8AD8D9468D4B4DDB80D58777F49DD7ED.jpg[/IMG]
[IMG]local://upfiles/78648/FAA9B253BCB9412EB4749B2C2655C262.jpg[/IMG]
[IMG]local://upfiles/78648/5C9DB7C2808B429D9C5B168E0A630834.jpg[/IMG]
Old Nov 21, 2007 | 09:57 AM
2006RamCrazy
ORIGINAL: Parts/Service
Thanks for the info
Jesse
Old Nov 21, 2007 | 10:13 AM
bwhite757's Avatar
bwhite757
Take your glove box out again, it would be UP and to the left, kinda right beside your factory radio. If not there, underneath the passenger REAR seat in a Quad Cab. If you still can't find it, take the passenger kick panel out, the plastic piece beside the door, it just snaps into place, you should see a black wire running from the rear of the vehicle up into the dash, there's and extension connector there, it's yellow with a red tab, that's the factory antenna wire, if that's there, then it has to be behind the glove box.
Here's a pic of mine, it was almost directly to the left of my radio:
But the above mentioned thread is also good to look at the diagrams, we had a discussion, what, 2 days ago?
Old Nov 21, 2007 | 11:16 AM
2006RamCrazy
ORIGINAL: bwhite757
I'm sorry, I didn't know this site existed 2 days ago....
Old Dec 30, 2007 | 06:45 PM
mbrady8's Avatar
mbrady8
On my 07 Its right above the glove box.... Here are some pics of my sirius install using the factory antenna....
[IMG]local://upfiles/80880/831DB10254A1485B8EBEF236E7FFD6FE.jpg[/IMG]
[IMG]local://upfiles/80880/3896B450074C44929514DDF524DEE77F.jpg[/IMG]
[IMG]local://upfiles/80880/88040FD276E24A59844B59F56F771711.jpg[/IMG]
[IMG]local://upfiles/80880/C513F6AB7EEA4651B1F83A040C549730.jpg[/IMG]
[IMG]local://upfiles/80880/72D7B491CB294E22B503916330940F78.jpg[/IMG]
