amp and sub question
I've pretty much decided that i'm gonna go with a pair of rockford p3 sd ten's for my dodge quad cab. How powerful of an amp do i need. Each sub puts out about 180 rms, 300 watt peak. So would i need around 400 watt rms ? What else should i look for. The amp will only run the two subs. Also what is the difference between two ohm versus 4 ohm in subs ? Thanks[align=left] [/align]
Yeah you should probably have a 400 Watt rms amp, you dont neccesarily have to have that much but your subs wont be at there full potential w/o that much. Most car speakers are 4 ohm. If your amp is 2 ohm stable thats when you could wire 2-4ohm speakers in parallel (benefit of this is most amps will push more power in a 2 ohm config then a 4 ohm). I have never heard that either 4 ohmor 2ohm speakers soundbetter than the other. I would always experiment whenI hooked subs up either running them parallel or series,on a single channelor indivdual. Maybe some1 on here knows the "perfect" way to hook them up indifferent configurations. Ialways tinkered with it untilI thought it sounded good.
I have a pair of rockford p3 10's w/ a rockford 400w amp in my '04, mine are bridged to get the most power out of the amp. It bumbps pretty good in cab (turns my stock seats into massagers
) but its not real obnoxious outside the cab. Noting rattles like most of the little rice burners do. Thats my $0.02 on the matter.
I am waiting for delivery on the MTX thunderform matched with a kcker amp. I will let you know how that goes. MTX wired the two subs to be at 2 ohm. The Kicker is stable at 2ohm, so we will see how it goes. That install is next week's project!
RF p3's I think are dual voice coil subs. depending on how old urs are. newer ones I think are DVC. this changes how your wiring would be. two dvc subs thar are 4 ohm subs wired in parallel would be 1 ohm. if they are SVC then it's just 2 ohms. no difference in sound it's just the resistance of the sub. they olny have to do with wiring options. how many + and - plugs are there on each sub. if there is one of each ten its a SVC if it's two of each its a DVC.
