TIRE PRESSURE ??????
Old Nov 26, 2007 | 02:59 PM
TANKZ400's Avatar
TANKZ400
Default TIRE PRESSURE ??????
How many pound's are you guy's running.
Old Nov 26, 2007 | 03:03 PM
berg501's Avatar
berg501
Default RE: TIRE PRESSURE ??????
My truck has the factory 20's and I run 42 psi in them.
Old Nov 26, 2007 | 03:06 PM
TANKZ400's Avatar
TANKZ400
Yeah I have the factory 20's as well.
Old Nov 26, 2007 | 03:15 PM
abarmby's Avatar
abarmby
35 psi all around on my 20's.
I get even wear especially when rotating at 5000 miles as well.
Al
Old Nov 26, 2007 | 03:21 PM
CarGuyOhio's Avatar
CarGuyOhio
I also put 35 in them. I think 42 is over inflated if I recall. The recommened PSI should be inside your drivers door jam or on the door itself.
Old Nov 26, 2007 | 06:06 PM
JD1500's Avatar
JD1500
20"s stock rubber ant toyo at's. 36psi. Bump up to 40 when towing my heavy *** trailer
Old Nov 26, 2007 | 06:15 PM
HammerZ71's Avatar
HammerZ71
My 35" FCII's call for a max. of 50 lbs. I run them all at 40 lbs.unless I'm off roading, then I'll bring them down to about 35# or even lower if it's fun in the mud time or I'm in heavy sand.
Old Nov 26, 2007 | 06:37 PM
07 Ram TRX4's Avatar
07 Ram TRX4
I've got the 17's on mine.... and i forget what the pressure is... i wanna say about 35.... could be wrong.... hmm.. probably should check em.....
Old Nov 26, 2007 | 06:42 PM
Jus Cruisin's Avatar
Jus Cruisin
I'm running 38 in my stock twenty's. I ran 40+ in the twenty's on my '04 and wore out the centers.
Old Nov 26, 2007 | 07:41 PM
Newbeme's Avatar
Newbeme
I have the 20's and I'm running 35lbs also.
