Noob questions continue. Front diff level check.
Old Nov 29, 2007 | 10:41 AM
ScottJ175's Avatar
ScottJ175
Default Noob questions continue. Front diff level check.
OK, so I've looked and looked at my front diff and can't figure out where the stinking fill plug is to check the fluid level.
Old Nov 29, 2007 | 11:03 AM
NYPANAMA42's Avatar
NYPANAMA42
Default RE: Noob questions continue. Front diff level check.
I couldn't tell you..but, hang on one of the other guys will answer it for you. Check with HemiYellow or one of the others.
Old Nov 29, 2007 | 11:36 AM
tdmopar59's Avatar
tdmopar59
hemi yellow is 2wd!!! i have a 2500... my front dif is the same size as your rear the bolt on mine is right on the front near the right side if your looking at it.... unless its leaking you should be fine...
Old Nov 29, 2007 | 02:19 PM
LoFlyer's Avatar
LoFlyer
The front diff has a black plastic plug on the front locatedbelow the breather hose outlettube.
Old Nov 29, 2007 | 02:46 PM
ScottJ175's Avatar
ScottJ175
ORIGINAL: LoFlyer
Hmmm, I don't recall seeing one there but I'll look again.
Old Nov 29, 2007 | 04:50 PM
LoFlyer's Avatar
LoFlyer
If you're standing in front of the truck and looking at the front diff, it's on the far left side of the front cover.
