View Poll Results: A poll
K & N
40.78%
TrueFlow
11.17%
AEM
7.26%
S&B
2.23%
Air Raid
8.94%
Varram
2.23%
Volant
10.06%
Afe
2.79%
Air Ram
2.79%
Other
11.73%
Voters: 179. You may not vote on this poll
Cold Air Intakes
Old Dec 26, 2007 | 09:57 PM
  #41
BHRAM's Avatar
BHRAM
Default RE: Cold Air Intakes
ORIGINAL: HammerZ71
BHRAM, really any name brand that is a true CAI isa goodimprovement over stock. I have the K&N but mainly because I got a deal on it at the time, plus I've been using their drop-in filters with good results for years. Whatever way you go, I think it's important to go with one that replaces everything from the throttle body out. The stock air box and especially that big plastic baffle over the throttle body are quite restrictive. The newer TrueFlow XDi, the AEM Brute Force and K&N would be just a couple of good choices.
An important thing to remember is that performance increases as a direct result of increased intake AND exhaust flow. A CAI is really a waste without at least a good cat back exhaust system.Headers would also compliment the system nicely.
well im planning on getting a magnaflow catback and the K&N CAI together got a friend that can get me a good deal on them
Old Dec 28, 2007 | 09:18 AM
  #42
HankL's Avatar
HankL
there would be a lot of confusion and mis-information
if the dashboard of pickups didn't have
gauges for oil pressure, coolant temperature, fuel tank level, tachometer, etc.
Most of the mis-information about cold air intakes comes because
there is not an easy way for the owner to see his MAP and IAT sensor reading.
Most of this would go away if the dashboard had a gauge for
air filter restriction...which is common on 18 wheel trucks.
In the pdf file from Donaldson filters below
scroll down three quarters
and look at the guage for the dash labeled
"Service Gauge for Instrument Panel"
http://www.donaldson.com/en/engine/s...ary/053979.pdf
If the Ram dashboard came with a guage like that
most cold air intakes would be returned for refunds
especially after owners noticed the new washable filter
clogging up at a faster rate than their paper filter did.
Old Dec 28, 2007 | 01:28 PM
  #43
tdmopar59's Avatar
tdmopar59
it was only a matter of time b4 HankL would try to ruin this thread...
ATTENTION ALL NEW GUYS: Never Listen to HankL!
Old Dec 28, 2007 | 01:44 PM
  #44
HammerZ71's Avatar
HammerZ71
ORIGINAL: tdmopar59
Damn biotch, that's what all the old timers here told me about you!!!
Seriously, when it comes to Hanky, use the little red hand guys...
Old Dec 28, 2007 | 01:47 PM
  #45
pcollins's Avatar
pcollins
It was only a matter of time
Hi Hank! [8D]
Old Dec 28, 2007 | 04:08 PM
  #46
HankL's Avatar
HankL
Isn't adding another valuable gauge to the dashboard a good mod?
Cummins Ram owners seem to take delight in
Transmisson temperature,
EGT and
Lift pump pressure gauge additions,
so shouldn't gasoline Ram owners get in on the fun?
Dodge Ram owners should not be ones who fear to know....
Old Dec 28, 2007 | 04:48 PM
  #47
bwhite757's Avatar
bwhite757
ORIGINAL: HankL
So I'm going to return my washable/reusable filter because apparently it's doing a better job than my old paper one? If what you say is true, it's apparent that a K&N or Trueflow (Just examples) is keeping more particles inside the filter than letting them pass into the engine. WoW, man I need to go throw my K&N away right now, because I want that crap that's getting through the paper filters and not clogging them up to end up in my engine.
True Flow has a video actually saying exactly what you just did, showing how a K&N filter will clog a little faster than the paper filters, b/c there is only so much room the guaze can store the dirt, they were showing off how their filters didn't do that. But they also showed just how much crap can get through a paper filter, and it was a horrifying video if you have a stock paper filter in your truck. I want to get to 200,000 miles on my truck, and I believe an aftermarket filter would be a benefit to my engine's long term care, and help me get to that goal.
Old Dec 28, 2007 | 09:09 PM
  #48
BadRam1's Avatar
BadRam1
I'm seriously considering investing in a CAI for my '02 4.7L 1500. I have some questions though.
1) On TrueFlow's website, the XDI is offered for '05-'07 4.7L. Is there a difference between my engine and that of the years listed?
2) K&N offers the FIPK and 77 for my truck. What is the difference? How much money am I looking at for either one of these?
3) Will it make any difference in sound with my single chamber muffler?
Old Dec 29, 2007 | 01:53 AM
  #49
tdmopar59's Avatar
tdmopar59
ORIGINAL: BadRam1
you might have a little more throatier sound.... the k&n 77 series has a chrome intake tube and offers slightly less power than the FIPK... as far as changes in the 4.7 im not too sure... the sealed intake works great too though...
Old Dec 29, 2007 | 03:38 AM
  #50
spud11's Avatar
spud11
Not too much differerence, just programing mostly. The TB size is still the same on both. I belive the FIPK repaces your entire intake system, it deletes the stock air box and that dam baffle box attatched to the TB. Either way, I'd check out the Air Ram website and look at the power scoop he has there, it'll help get more air to your cooler ouside air coming in thru the grill to your CAI. Again I'm looking at his pictures and seeing if I an't use my HVAC job to try and make my own, If I can't I'll just have to cough up the doe and buy one. Thats a suggestion that everyone should look into I think. Maybe evin our resident genius Hank might want one.
