rear door electrical
Problems with rear door speaker, PW, or PL? Check wire harness inside door jam boot. I had over half of the wires broken inside from regular use of the door (70k). Dodge is still isn't using their Mopar Magic on their wiring. I thought that was something they cleared up years ago. So happens if you ever have PW failure, the window works going down but not up every time, with a 70% that it will be raining
Last week I had 4 bad wires in my passenger rear door. The door lock would wirk with the door closed but not when it was open also the interior light would not work when the door was open. The wires are in a bind, I was told that it was a bad design.
