Exhaust question.
Old Dec 17, 2007 | 12:07 PM
dwoods's Avatar
dwoods
Default Exhaust question.
I put 12" glass packs on my 02 1500 about 3 months ago. if i have the converter cut off and run true duals will it be louder and or make the dreaded check engine light come on?
Old Dec 17, 2007 | 03:38 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Exhaust question.
If you remove the CATs it will be louder.
You will get a Check Engine light unless you buy sims.
You also stand the chance of warranty work difficulty.
Old Dec 17, 2007 | 03:57 PM
OldMoparMan's Avatar
OldMoparMan
ORIGINAL: dwoods
Yes.
Converter removal will make it louder, then as the glass packs wear out, it'll get even louder.
With the way that inspections and federal laws are changing, I wouldn't suggest removing cats either, or at least if you do, don't throw them out......
Check engine *may* come on, as well. Your results may vary....
Old Dec 17, 2007 | 09:18 PM
bobbylight's Avatar
bobbylight
^^^^^^^^^^^TRUE^^^^^^^^^
Old Dec 17, 2007 | 11:56 PM
tdmopar59's Avatar
tdmopar59
another way to prevent the light from coming on is the non foulers... but yea inspections would be a PIA
