Wierd NOISE
Old Dec 22, 2007 | 12:10 AM
bobbylight's Avatar
bobbylight
Default Wierd NOISE
today, i noticed that if i was going over 10 miles and hour and put my truck in neutral, right before i came to a stop i would hear a clunck noise and i felt the truck jerk a little bit. It was wierd because it will only do it in neutral and not drive. the noise sounded like it was coming from the rear of the truck. What might this be and should i be worried?
Old Dec 22, 2007 | 01:48 AM
JD1500's Avatar
JD1500
Default RE: Wierd NOISE
not sure but it could be your tranny coming out of gear under load/power. why are you shifting to neutral anyway? manual?
my jeep did that and had a bad throw out bearing, but i will admit, i have no idea what is going on with yours
Old Dec 22, 2007 | 09:14 AM
bobbylight's Avatar
bobbylight
It is a automatic and i just felt like shifting into neutral for no reason and i heard this noise. And it doesnt do it right when i shift into neutral. It does when I come to a stop after being in neutral for 15 seconds or so.
Old Jan 1, 2008 | 01:20 AM
06 ramguy's Avatar
06 ramguy
torque converter maybe?
