2004 Ram Electrical Problem / Pls help
Old Dec 28, 2007 | 08:17 PM
TSmith1926's Avatar
TSmith1926
Default 2004 Ram Electrical Problem / Pls help
Got in the truck yesterday morning, it cranked like normal, but no gauges, inside lights, turn signals, wipers. Radio works fine. It drives fine, but like I say, nothing I mentioned works. Anyone?
Old Dec 28, 2007 | 08:28 PM
JD1500's Avatar
JD1500
Default RE: 2004 Ram Electrical Problem / Pls help
A straight up guess would be either a fuse, or bad/ground or wire. Check there, and hten unfortunatly you might have to hit the stealership
Old Dec 28, 2007 | 11:57 PM
MadMaXxX's Avatar
MadMaXxX
yea check for fuses, another thing you could try is turn the ign 3 times, dont start it just do a lock to run position 3 times, this will usually do a self test on the cluster, if you are under 36k and depending on when your truck was purchased(went into service) it might still be under warrenty, some dealers if you have a good record with them will do a "good will" warrenty if you are just a tad out of the mileage or age warrenty
hope this helped out some....
