04 Ram Wipers problem
Old Dec 29, 2007 | 08:45 AM
04MOPAR's Avatar
04MOPAR
Default 04 Ram Wipers problem
Well, my wipers work, but only thing is, when I turn them off instead of returning to the bottom of the winshield, they goto and stop in the middle of the windshield! What to look for?
Old Dec 29, 2007 | 12:02 PM
chadmech28's Avatar
chadmech28
Default RE: 04 Ram Wipers problem
pretty common problem sounds like the park switch inside the motor has a bad contact. If you have a scanner you could probally get a dtc for park switch. I would just replace the motor this will fix your problem.
Old Dec 29, 2007 | 12:33 PM
hemiyellow's Avatar
hemiyellow
DC Insider
same problem on mine...wiper motor, PCM and FCM and been replaced...none of em fixed the problem...i'm gonna try replacing the switch in mine cause i can get it to act up if i want to by playin with the switch so the switch should fix it
Old Dec 29, 2007 | 05:43 PM
04MOPAR's Avatar
04MOPAR
ORIGINAL: hemiyellow
Hemi, whats PCM and FCM? Wonder if I can check those out on mine. Thanks.. If not I wonder if It will be cover under the MAX care extended warranty..
Old Dec 30, 2007 | 02:22 AM
hemiyellow's Avatar
hemiyellow
DC Insider
PCM - Powertrain Control Module
FCM - Front Control Module
