Cluster lights and gear select light problems..
Old Jan 7, 2008 | 12:17 PM
zman9119's Avatar
zman9119
Default Cluster lights and gear select light problems..
Ok, so I had nothing to do this weekend so I installed a Commando FM-870 (I know, not the best) remote starter in my 2003 Dodge Ram 2500. I am using the CHDL3 bypasskit also for the locks.
Everything works great, except anytime when the lights flash (unlock or lock), my instrument cluster backlights flash too. Also, my gear selector indicator kit and odometerlights are lit at all times.
Is this due to me forgetting to put the correct resistor on the purple\yellow (connected at the headlight switch) or should I dive in somewhere else to try to resolve this?
I removed the tap at the headlight switch but forgot to test to see if the lights did not flash (me=stupid), but the gear select light and odom light stays on. Is this due to door ajar switch?
Im lost this morning.
Thanks, this is a great site.
.z
