belt squealing..
Old Jan 12, 2008 | 12:36 PM
matsram's Avatar
matsram
Default belt squealing..
not sure why but last couple of weeks once in a while when i start my truck the belts squeals and amp gauge is way low first time it happened i turned it off right not really sure why it was squealing checked under the hood all looked ok resarted and was fine, now i've noticed that the amp gauge is low when it happens i shut it off and restart and all is fine. why is my hemi ram doing this, ive never messed with the alternator or battery and why only once in a while. any help thanks.
Old Jan 12, 2008 | 01:00 PM
Mattcmdr's Avatar
Mattcmdr
Default RE: belt squealing..
yea the belt is sqeeking becasue you alternater is having to work to get you voltage up(not sure why ur volts are low something seems to be draining them check that out deff) and that belt could be old, could be cold cuz its winter and just not very plyable, or it jsut feels like sqeeking.then again belts just like to sqeek
Old Jan 12, 2008 | 01:25 PM
herring_jerritt's Avatar
herring_jerritt
sometimes in the morning, if it is damp out side or raindin, my belt squeeks, but thats just because of the wetness on it, but as for your amps i have no idea
Old Jan 12, 2008 | 03:14 PM
MikeHTally's Avatar
MikeHTally
What year is your truck? How many miles? I'm wondering about the belt tensioner or an idler pulley. A squeaking belt isn't tight enough. Since there is no manual adjustment, I'd guess the tensioner needs to be replaced, along with the belt.
Old Jan 12, 2008 | 04:47 PM
Gone Fishin's Avatar
Gone Fishin
I think I'd start with a Goodyear Gatorback serpentine. I suspect that your belt is worn/stretched and the tensioner is at its limit, or close to it. I also would guess that the squeal you hear is the slippage on the alternator pully at start-up----the heaviest amp draw period from the Battery.
Old Jan 12, 2008 | 07:11 PM
moparman2k2's Avatar
moparman2k2
tensioner and belt replacement
Old Jan 12, 2008 | 08:05 PM
LoFlyer's Avatar
LoFlyer
yea, check the belt tensioner. You'll see scribes on the tensioner body, the part bolted to the engine, that are marked "I" and "II". On the part of the tensioner with the pulley you'll see an arrow stamped into it. If the arrow is maxed to the I or II then you are at max travel and either the belt is worn or the pulley spring is shot.
Old Jan 13, 2008 | 01:05 AM
HighDuke1911's Avatar
HighDuke1911
or just rub it with some bar soap on the belt. that always does the trick.
Old Jan 13, 2008 | 02:12 PM
matsram's Avatar
matsram
thanks guys for all your advice, had a bad day yesterday belt wouldnt stop squealing every time i turn the heater on and the daytime driving lights are on its loading up the alt. so much that the belt stops. the guys (counter sales)at bill suburban alternator and starter checked it out and thought the same thing up until the old man in the shop that rebuilds them came out and looked at it, he pulled my belt and gave the pulley a spin and nasty growl yelled out and by the looks of the engine compartment turns and says been off-road lately? due to water,mud and snow some of witch must have made there way into the alt. bearings 70 bucks and two hours on monday it will be repaired. thanks again for all your thoughts.
Old Jan 13, 2008 | 05:42 PM
Gone Fishin
Glad to hear you figured it out!!!!
Cheap repair too, Good thing you caught before the alt fried. That sort of thing can wreak havock with your electrical system, and ECM.
MAKE SURE THE GUY REPAIRING IT GIVES IT A GOOD CLEANING INSIDE TOO, MIGHT HELP SAVE THE WINDINGS.
