Question on towing trailer...
Here is a link that might help.
http://www-5.dodge.com/towing5/D/vehicle_to_weight.jsp
All mega cab trucks are de-badged 2500s. Same frame, same gears, same powertrain. They need that frame to mount the large body and bed and to handle the weight of the total assembly.
Going by the door sticker you'd be at or near your limit. Going by the vehicle's build you'll still be comfortably within its bounds of towing. You won't get the gas mileage a diesel would but it isn't unsafe either.
My understanding though (and I could be wrong here) is that even though the frame is the same, there is a suspension difference between the two that causes the difference in tow rating, and makes the 1500 mega a 1/2 ton vs. 3/4. If anyone out there with a 2500 mega cab can check, my (stock) rear suspension has 4 leafs (leaves??) - how many does yours have?
Sean
Sean
i work at u haul and i instale hitches so please know that just becasue the manufacture tellsus how muchour trucks can towour hitchsare only rated at 5,000 lbs without weight diturbution.
so why are they saying that they will haul different loads if they are the same thing ?? As noted are there not more springs in the 2500 vrs the 1500 ?? It just doesnt make sence why they would label them with such different load ranges if they were the same ??your thoughts ?
From what I've found, the 1500s and the 2500s have the same frame but the 2500shave a different leaf spring setup anddifferent\heavier axles. I'm not sure about the mega-cabs if they are rebadged 2500s or not.
Mike
Mike
