A/C Problem
Old Jan 15, 2008 | 09:51 AM
ctd4x4's Avatar
ctd4x4
Default A/C Problem
I know a lot of people have had trouble with the air conditioning system on 3rd-generation Rams. I have a 2005 2500.
I've taken it to the same dealer 3 times for the same problem, and each time they charge the system, put in dye, and cannot find any leaks.
The problem is that cold air ONLY blows from the two driver-side vents. The passenger side vents are blowing ambient or outside air.
Would it do me any good to try another dealer? Also, I heard somewhere that there's a restrictor filter in the A/C system that can be removed to make it blow harder.
The A/C in this truck is very weak, overall.
Any help would be appreciated (especially before summer).
Old Jan 15, 2008 | 02:38 PM
BHRAM's Avatar
BHRAM
Default RE: A/C Problem
they probably didnt find it because the leak may be inside the cab where the evaporator is
Old Jan 15, 2008 | 07:08 PM
Gone Fishin's Avatar
Gone Fishin
Chances are that given the reasons above, I would guess your problem is in the HVAC portion of the system, as in the doors aren't working right. If in fact the refrigeration portion of the system is leaking, then when they pulled the gas out---and they should have----to weigh it.
A simple leak check with an electronic leak detector would have shown up. They can find a leak down to 1/4 oz/year leak if they're using the right one.
If they're just adding gas, theres also a better chance that you are now overcharged, with gas and money for the work.
Old Jan 15, 2008 | 07:29 PM
Parts/Service's Avatar
Parts/Service
I see this problem several times a week. If the air is less on the passengers side than the drivers. the way to solve this is to replace # 4 in the pic below. Hope this helps. PM me if you have any questions. It is called a "heater and A/C unit case" Hope this helps...
Old Jan 15, 2008 | 10:27 PM
Wishbone's Avatar
Wishbone
One question though, it's freakin' January. What are doing running with the AC on? [&:]
Old Jan 15, 2008 | 11:12 PM
Parts/Service
I had the Air on today. It was 29 when I got up and 65 at 3pm
Old Jan 15, 2008 | 11:36 PM
onephatcracka's Avatar
onephatcracka
number 4 in that picture is replaced alot. but that is the recirc door. the complaint is usually a vibration on high, or vents do not change.
I had an issue with temp at one point. I was told by engineering that a difference in 12 degrees is normal because of the design of the box. I was told that there have been cases of 25 degrees and chrysler wasn't doing anything to fix them. its just bad engineering. The dealership can try to calibrate the doors. but thats all they can do if all pressure are ok. Its more of an air flow in the box issue then a refrigerant issue.
I hope that helps
