Question about Engine Flush?
Old Jan 21, 2008 | 01:45 AM
turbot_bird's Avatar
turbot_bird
Default RE: Question about Engine Flush?
ive used the additives before in my older motors. havent used it in the dakota because I dont think that it needs it yet. the motors I have used it on had 150k plus and mostly fords since those are the ones ive seen with the most buildup in them.
Old Jan 21, 2008 | 06:24 AM
HankL's Avatar
HankL
learn about the guts inside a hydraulic lifter.
the more you learn about the extremely tight tolerances and fits inside a hydraulic lifter, the less you will want to try engine flushes or old myths about adding atf to your engine oil
if you have a MDS equipped 5.7V8
your hydraulic lifters are even more complicated
from
http://www.popularmechanics.com/auto...26.html?page=3
