ideas for a low buck lift and towing capacity increase
KX250 Showed Me The Ride Rite Bags He's Talkin About... I Always Figured Bags = Fab Up + Air COmpressor + Regulator + Bags + Tubing Equaling A Damaged Wallet and I Fricken Headache. The Bags He Showed Me Simply Bolts Up And Uses Tubing That Runs To The Rear - Thats Where You Full The Bags.. Nice Ghitty Up For $250, He Says.
If Thats All True and Works Like Standard Bags... THATS THE WAY TO GO One Man Gang.
Thanks Again KX250
Thanks Again KX250
blocks will make ur springs sag faster , and add a leaf will make ur ride stiffer , get the bags best bet, the rancho quick lift for the front is a waste i find. maybe get a leveling kit from rock krawler its cheap and looks easy to do.
i've got the timbren's...they replace the bumpstops and stick down farther. the truck will start to sink a little then make contact w/ the new "bumpstops", which aren't bumpstops...they are rubber springs.
there is about 2" (if i remember right) between the springs and the timbrens. when used w/ the rancho 9000 shocks, a heavy load in the bed doesn't rock/sway/bounce down the highway like it would w/ stock set-up.
