true dual or dual outlet
Old Jan 24, 2008 | 08:45 AM
hugekikd 2007's Avatar
hugekikd 2007
Default true dual or dual outlet
Is there a big different between the two of them and how many of you guys run a true dual.
Old Jan 24, 2008 | 09:04 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
Default RE: true dual or dual outlet
i don't have a true dual.
but yea...hope this helps your research:
http://www.youtube.com/watch?v=WeKxdjM-9pY
Old Jan 24, 2008 | 09:35 AM
HammerZ71's Avatar
HammerZ71
I've never run a true dual in my life, but that's not to say I disapprove of them. When I was a yungin' in the 80's and started welding my own exhausts (as well as other peoples) the one who kinda guided me the first time had me weld an "H" pipe when I did my '73 Nova SS. So, I always did at least an "H" even with a system that was dual right down to having two mufflers. Just the way I was taught, like I said, I have no clue whatsoever which is better, it's just the way I've always done it.
On my current truck, I've got the LT Headers going through 2 cats and don't meet until a "Y" just before the muffler (a one in/two out FM 50HD) so then it's back to 2 tailpipes.
Old Jan 24, 2008 | 11:00 AM
Hellbilly1's Avatar
Hellbilly1
well from what I was told with True duals you will lose low end torque unless you have headers.. I dont know if that happens with the H pipe or what but thats what the exhaust shop told me anyways.
Old Jan 24, 2008 | 01:34 PM
SLCHemi's Avatar
SLCHemi
I'm by far not an expert, but truely love muscle cars and sports cars and have enjoyed a few, and have many friends in the same circle. The "common" thought seems to be that you should always use an "H" or "X" pipe to help balance the pressure in both cylinder banks. I can't recall seeing a high-end exhaust setup for an 8cyl that didn't have this (though I have seen a few "redneck specials that have straight pipes welded with coat hangers...ugh!). In terms of pipes themselves, my limited lay-person understanding is that it all boils down to flow (CFM's). Your looking for optimum flow but need a little pressure to maintain torque (except on say a turbocharged engine where the turbo might provide the backpressure). All that said, if I were going from a single 3" pipe to a dual I'd probably consider using 2" or maybe 2.5" piple per side with an H pipe up front (not far after the cats). Maybe someone who knows more than I will chime in and can give better advice on pipe diameter in terms of optimum flow vs. backpressure needed for the 5.7L....
Old Jan 24, 2008 | 02:22 PM
kenihemi's Avatar
kenihemi
Won't make a difference.
Old Jan 24, 2008 | 02:26 PM
hugekikd 2007
thank you guys for all of your help
Old Jan 24, 2008 | 03:22 PM
hugekikd 2007
i am thinking of going with a flowmaster 44 with a dual outlet
Old Jan 24, 2008 | 03:46 PM
Hemipwr07's Avatar
Hemipwr07
that would be a good choice. i got the 50 series dual outlet but pretty soon im gonna switch to a 40
Old Jan 24, 2008 | 03:51 PM
TANKZ400's Avatar
TANKZ400
I've done true dual on my 71 nova and my 77k20 but i dont think it's a good idea to do unless you have 400hp plus.
