Auto Head Light Switch
Old Jan 24, 2008 | 08:41 PM
jesseh627's Avatar
jesseh627
Default Auto Head Light Switch
I miss my auto headlight switch I used to have on another vehicle. Has anyone switched out their stock switch for an automatic one? Anyone seen an aftermarket option for this?
Old Jan 24, 2008 | 09:31 PM
Foiled's Avatar
Foiled
Default RE: Auto Head Light Switch
I miss alot since I do not drive the Lincoln much anymore.
Auto lights, Auto Wipers, Auto up and down on both front windows, Auto mirror dims on inside and outside. Lowering all windows and opening the sun roof with the keyless remote. Closing all windows and sunroof with the drivers door lock and the key pad on the drivers door unlock with out the keys. Seat, steering wheel, mirror's and gas/brake pedal memory and 2 presets. Programming the remotes to remember who unlocked the car and it sets the seats, pedal's, steering wheel and mirrors to your settings. Heated and AC cooled seats.
I think I miss the advance trac the most. You can keep it on and you can't spin the tires even on wet roads. So no more fish tails when entering traffic quickly and you can turn it off if you want to play.
They don't call it the Ultimate edition for nothing I guess. The wife sure does like driving it though.
Old Jan 24, 2008 | 11:04 PM
MikeHTally's Avatar
MikeHTally
This gadget and a bit of wiring will give you auto headlights.http://cgi.ebay.com/ws/eBayISAPI.dll...:IT&ih=010 There's a nicely-done "how to" on this forum, I believe. I've only read through it once. As I recall, you'll need one more relay, but otherwise, it's all there.
Old Jan 24, 2008 | 11:13 PM
MikeHTally's Avatar
MikeHTally
Whoops, not this forum. Try this: http://www.dodgetalk.com/forums/showthread.php?t=158837You may need to copy & paste.
SmittyRN's Avatar
SmittyRN
I've always wondered if you could get the parts from a 300 and install them in a Ram. I miss the auto-headlights too, after using them for the past 4 years now I'm forgetting to turn them on or off.
Old Jan 24, 2008 | 11:17 PM
MikeHTally's Avatar
MikeHTally
ORIGINAL: MikeHTally
What a surprise.
Old Jan 25, 2008 | 09:00 PM
jesseh627's Avatar
jesseh627
Mike even if you could wire the auto on/off switch into the normal headlight switch. I wouldn't necessarily have to have the sensor that goes with many of the systems, you know, they don't come on uless it is dark enough outside.
The last 3 vehicles and our current Town & Country just have auto on lamps. When you crank it and the lamps are in the auto setting, they come on.
What do you think?
Old Jan 25, 2008 | 09:23 PM
MikeHTally's Avatar
MikeHTally
ORIGINAL: jesseh627
What do you think?
An excellent point. I don't know if this after market unit has any kind of sensitivitysetting. My C has an "easter egg" in the EVIC, allowing the owner to change a few things, one of which was the sensitivity of the auto lamps. I turned mine down a fair bit. I didnt' like the factory default setting, so I turned it down (up) so the lights come on much sooner.
