Another Heat Problem (fan/blower)
Old Jan 25, 2008 | 05:02 PM
uponone's Avatar
uponone
Default Another Heat Problem (fan/blower)
My fan is only working on the highest setting. I have a 2003 Dodge Ram 1500 Hemi 4x4. All the zones work properly, and the temperature adjustment dial works fine. But my fan speed (I have speeds 1-4) only works on 4 (the highest). About a month ago I noticed the fan going on and off as I was driving...now it doesn't work at all on the first three settings. Any clues on where to start trouble shooting? THANKS!!
Old Jan 25, 2008 | 07:48 PM
Petz's Avatar
Petz
Default RE: Another Heat Problem (fan/blower)
I would suspect that you start with the fan selector switch and ensure all contacts are made. The fact that it went on and off suggest you may have a loose connection somewhere in the system. Check a component and resistence and work down the electrical path.
Old Jan 27, 2008 | 10:46 AM
glbales's Avatar
glbales
Had to replace the switch at about 70k previous owner was switch happy. Headlight switch went out at 90K
Old Jan 27, 2008 | 01:08 PM
redtruck2500's Avatar
redtruck2500
On my old Ford , there was a resister that went bad under the hood.
Old Jan 27, 2008 | 03:22 PM
uponone's Avatar
uponone
Weird...I was going to look at it this morning and its all working now. Hmmm, must be a bad connection somewhere. Needless to say, its about 20 degrees outside so I left well enough alone. I'll look at it when I have to. ha.
Old Apr 12, 2008 | 01:05 PM
uponone's Avatar
uponone
Well, it worked for a while...now it stoped. So I'm back onto fixing this problem. The same thing is happening, the fan speed selecter switch only works on high. I took it all apart and cleaned the contacts...no change. Any hints on what to do next? Does anyone know where on my truck the resistor is located?
Thanks.
