Problems with new lights
Old Jan 31, 2008 | 09:22 PM
PanzonYMariposa's Avatar
PanzonYMariposa
Default Problems with new lights
I just installed a new set of CCFL halos to replace my LED ones and I've run into a problem. I am positive that everything is wired correctly but I've lost the parking lamps function on both my new headlamps and my taillamps on the driver's side only. The passenger side lights all work perfectly fine. I looked to see if I blew a fuse but it seemed fine. I have an 03 QC. Does anyone know if there is a different fuse I should be looking for? I pulled out a 50amp fuse out of slot 15 but that didn't change anything. I've had problems with my taillamps before because of a bad seal but would that affect my headlamps as well?
