RC Ram HEMI 1/4 ?
Haven't had mineat the track yet but from what i've read on here the average seems to be mid 15's @ high 80's. Of course if you're lower geared and can hook a good 60' you'll do better.
Your 1/4 mile times bone stock should be around 15.30-15.50.
A loaded 4x4 will be .3 to .5 slower. Weight of truck, temperature, and traction will determine final results. A light truck with 3.92 and LSD (posi) will of course be faster than a heavy one with "pegleg" and 3.21 gears. my truck went a full second faster with superchips, a cat-back exhaust, k&n drop in filter, and a transgo shift kit. best bang for the buck was a tie between the superchips and the shift kit. I suggest the superchips first, followed by the air filter, then exhaust. the shift kit is $$$$ unless you install it yourself.
