ReadyLift leveling kit installed!
Old Feb 5, 2008 | 10:27 AM
kregier's Avatar
kregier
Default RE: ReadyLift leveling kit installed!
Looks really good. I sometimes wonder if I should have done the spacers instead of cranking my torsion bars. But, if I do eventually end up lifting it, the spacers would have been a waste.
Old Feb 5, 2008 | 10:29 AM
mmstar23's Avatar
mmstar23
for the 4x2 go to fatbobsgarage.com the have the polyurethane spacers made by daystar. $80 they have a 1.5" spacer and the 2" spacer im gonna get in a few weeks
Old Feb 5, 2008 | 11:25 AM
Secretlover's Avatar
Secretlover
I have a set of polyurethane 3" spacers on my truck to level it out. I put them on 2 years ago and they now seem to be crushed. I would recommend not getting the polyurethane, unless you don't mind replacing them every couple of years. Also tocompress the coils springs I rented a set of compressors form a local auto parts store.
Old Feb 5, 2008 | 12:20 PM
redbeardmcg's Avatar
redbeardmcg
Sweeet. So far all I've done to my truck is Volant CAI, Flowmaster 50, and readylift leveling kit, and the leveling kit has definitely been my favorite mod!
Old Feb 5, 2008 | 02:29 PM
XxSilentHawk99xX's Avatar
XxSilentHawk99xX
looks good man....I should get some pics up of mine with the 3" lift kit i just threw on
Old Feb 5, 2008 | 04:27 PM
mmstar23's Avatar
mmstar23
the polyurethanes crush? meaning squish down and shrink? that sucks! unfortunalty for the 2wd thats about the only option
Old Feb 5, 2008 | 05:36 PM
Hemipwr07's Avatar
Hemipwr07
ya get those pics up. you dont need a coil compresor i dont think. you jus take the coil out as a whole still in it bracket so it doesn come undone. but ya iv heard polyurathanes crush and stuff. the readylift spacer is steel. why couldnt you use it for the 4x2? is there a big difference in body style or something? you would think it would fit
Old Feb 5, 2008 | 08:29 PM
JD1500's Avatar
JD1500
If you dont wanna rent a compressor, you can do it with another jack. Use another jack and a piece of wood to compress the spring a little. take off your spring hardware from the top of the fenderwell, and let down on the jack real slow. Do the same in reverse to get them in.
Old Feb 5, 2008 | 08:52 PM
mmstar23's Avatar
mmstar23
ok thanks a lot JD1500. can you explain a little more in detail about using a second jack to take out the coil? sorry.
Old Feb 5, 2008 | 10:40 PM
Hemipwr07's Avatar
Hemipwr07
yo im pretty sure you dont need to re-compress the spring. at least not with the ready lift system. if you need if for somethin else your getting tell me to shut up ha but i dont think you need it. course i may be wrong. and does anybody kno y the 4x4 readylift kit wouldnt work on a 4x2? wats the big difference that it wouldnt work?
