04 ram 1500 cams?
Old Feb 4, 2008 | 08:02 PM
redneckracer1966's Avatar
redneckracer1966
Default 04 ram 1500 cams?
I wanna put a big cam in my truck that gives it that off idle lope that lets you know it's a bad mother. I found on from crane cams a while back with around 580 lift. I can't find it now so does anyone know where i can find a cam like that? It's gotta be a bad mother cause I've got an srt10 to out run
Old Feb 4, 2008 | 08:14 PM
HammerZ71's Avatar
HammerZ71
Default RE: 04 ram 1500 cams?
You're gonna run into issues taming a big cam, get used to mutliple misfires even with a piggyback and a custom tune. BTW: You REALLY want to check out KRC Performance's CAMS. I'm going for a KRC 210 custom ground 4* advanced (a real torque beast grind!) but I'm waiting for the SCT tuner to be tested now that it's just been released for the Hemi. It will eliminate having to get the piggyback and can carry three custom tunes on it, unlike anything currently on the market.
Also be ready to get springs, retainers, rods & damper, not to mention headswiththe kind o***gressive lift you're talking, and don't forget the torque converter to get that power to the rear wheels...
But don't feel bad, I'm gonna have to do all but the heads to make my cam work with that grind...
Old Feb 5, 2008 | 12:01 AM
helopilot's Avatar
helopilot
ORIGINAL: HammerZ71
I have 10,000 miles on a Comp 268 and only 1 misfire code. I think it all depends on the truck.
Old Feb 21, 2008 | 05:59 PM
86Ram's Avatar
86Ram
hey im trying to figure all this stuff out and its takin a little while but i think im getting it if someone could tell me what the biggest difference is between the KRC 210 and the Comp 268 is it would be much appreciated and a big help thanks
