View Poll Results: A poll
New Rear Shocks
25.81%
Added Weight (bags of sand, lead, water, etc)
12.90%
Added Shell or Tonneau Cover
9.68%
Lower Tire Pressure
3.23%
Added Blinker Fluid
25.81%
Other
22.58%
Voters: 31. You may not vote on this poll
How Did You Stop the Freeway Bounce?
Old Aug 4, 2009 | 07:58 PM
  #31
VP64's Avatar
VP64
convert your truck to a longbed. and then convert the rear to coil suspension. and then air bag the whole truck
Old Sep 24, 2009 | 03:52 PM
  #32
Hardy's Avatar
Hardy
I feel your pain. I live in Los Angeles and know exactly what you are talking about. I love it when people say it's the road and not your truck. If it were the road it would do it for all cars. I have an old 1982 Dodge van that rides like a dream on the freeways. In fact all my cars ride nice except the truck. My nephew has a Ford truck and it bounces the same way on the freeway. I have taken my truck back to Dodge and their response is that it performs as expected. That's a nice way of saying they f'ed up on the design and you are SOL. The only thing that ever worked, I was moving my son and all his furniture was in the back (about 1500 lbs). The truck rode like a Cadillac. I once went to Home Depot and bought 10 90lb bags of cement to test it out and it still bounced. SOmeone told me that Monroe Magnums will help and I hear a lot of things about Ranchos. I may try the Ranchos becasue they are adjustible.
It seems that people not in Los Angeles don't have this problem. Maybe it's time to move.
I will definitely post the results should I find a solution or at least an improvement.
Old Sep 24, 2009 | 04:50 PM
  #33
slow2run's Avatar
slow2run
I'm on my third Ram diesel truck, That bounce is caused by the road condition,
What you can do to stop it, I don't know, but go towww.chryslergroupllc.com and each of you ask them by e-mail, when they know of the problem, then they will fix it, also they will find help for you from the Dodge Eng dept.
Old Sep 24, 2009 | 05:53 PM
  #34
70x7's Avatar
70x7
Originally Posted by BillSchmill
I love everything about my truck but I hate to drive it to work. I live in L.A. and drive ona concrete, sectional freeway everyday (which seems to be the worst case scenario for this problem). At 65-75 mph, the vibration is enough to rattle your teeth out at times. I've read several posts about this in this forum and it seems like there are a couple of ways to solve this problem. I'd like to see some percentages on what everyone who suffers from this problem did to solve it.
If you think you had this problem and solved it, pls be specific on what you did. i.e. how much weight did you load into the bed, which shocks did you use as replacements, what tire pressures did you run, etc...
Thanks for any and all info!
EXACT SAME THING!!!!!
There is a section of freeway that at the same speeds does the exact same. Other parts of the road, it is just fine. I thought it was suspension or maybe tire balancing. Took it in and they were off a bit and Discount said one rim was slightly bent and that could be the problem. I bought new rims and tires and it didnt fix the problem one bit. I figured it was a huge problem that was fixable, but if the same symptoms are else where, seems this is a huge problem that is permanent!!!
Old Sep 25, 2009 | 12:24 AM
  #35
Hoss356's Avatar
Hoss356
simple fix, in socal everyone's drives 85 anyway, either that or 5mph during the 23 hours a day of traffic. Oh yeah, the fix... don't drive 65-75. J/K
I'm thinkin shocks gotta be the best route honestly.
Old Sep 25, 2009 | 12:48 AM
  #36
OzzY04's Avatar
OzzY04
When I bought my truck, it bounced all over the place no matter what road I drove on. I though.. D*MN... I just bought an 04 P.O.S! But then I finally decided to check my tire pressure and the tards at the dodge dealersh*t had bumped my tire pressure up to 85 psi (i guess cause they read the max on the sidewall ). Anyways... I dropped all four to 35 and now it rides so much better than my old f250 or mustang.
Old Sep 25, 2009 | 10:12 AM
  #37
FFRANKIE's Avatar
FFRANKIE
I'm going to try that OzzY04.
When I first test drove my 05 it bounced very bad at 40 mph and then stopped under or over. It turned out that there were spacers installed on the front tires ( I believe they just push the tire out some) and when they were removed it stopped.
I do see when driving on a poorly paved road the truck suspension causes a bounce. Especially when going over a transitions like a bridge or exit ramp but always figured this is how trucks ride. Like a truck
I might try the Rancho if more people post they are getting good results with it. My wife complains but she drives a Sequoia SR5
and there is no comparison with that and any truck that I know of. Besides, I like to watch her bounce a bit
Old Sep 25, 2009 | 10:33 AM
  #38
kx250frider617's Avatar
kx250frider617
Just be glad you don't drive a ford f-350 dually. That thing is the worst on the 91. Even with the weight of 3 mx bikes and gear along with coolers, canopy. It still bounces like crazy.
Old Sep 26, 2009 | 02:25 PM
  #39
mbaseball3's Avatar
mbaseball3
dodge needs to make a california edition truck that'd be sweet! truck made for chitty socal roads. im sure you la guys are in the traffic as much as I am. I get bored and look at the pavement and in doing so you can see those what'cha ma call its every 15 feet or so. looks like rolling speed bumps basically. in my stupidity I've noticed a smooth ride above 80. but good luck ever getting a chance to do that
Old Sep 26, 2009 | 05:35 PM
  #40
jonaspowers's Avatar
jonaspowers
it is possible that an alignment could be due for you. road conditions are different everywhere. try it and post your results as some others have this problem. it's tough to blame it on dodge. don't think it wasn't worked out during the design of the vehicle.
