'05 1500 drivers side door handle
Old Feb 7, 2008 | 02:38 PM
sk425k's Avatar
sk425k
Default '05 1500 drivers side door handle
My outside door handle is loose, i just would like to know how to remove the door panel, i would guess that you have to remove this to tighten it?? thanks stephen
Old Feb 7, 2008 | 04:34 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: '05 1500 drivers side door handle
Moved to 3rd Gen section and a bump to the top.
Old Feb 15, 2008 | 11:13 AM
dwoods's Avatar
dwoods
theres a screw behind the door handle inside and a screw holding the door handle on pull the inside handle up and look down it'll take a stardriver to get it out. then take the triangular thing just above the panel off withby removing the two screws and pull up on the panel. thats it but i'm not sure exactly how to tighten the handle i've never done it
Old Feb 15, 2008 | 12:34 PM
Parts/Service's Avatar
Parts/Service
Remove screws # 2 and # 4 in the pic. Use a 10 mm socket to remove bolt that holds on inside door handle. Lift up on the panel to remove it...
