changing tire size.
Old Feb 11, 2008 | 07:32 PM
Buss's Avatar
Buss
Default changing tire size.
I want to go with a bigger rim and tire on my ram 4X4 short box hemi Muli. Do I have to reset computer? will it Change gas milage
Old Feb 11, 2008 | 07:35 PM
HammerZ71's Avatar
HammerZ71
Default RE: changing tire size.
Yes, to get the proper readings on your speedo and odo, you will need it set in the PCM.
Of course, you will get worse fuel economy with the switch to bigger heavier wheels and tires, the price you gotta pay...
Old Feb 11, 2008 | 07:41 PM
Tommygunz's Avatar
Tommygunz
You can go to the dealer and they can reset tire size in your PCM. I am doing it this week, they said 45 buck.. kinda of a rip, but it gets the job done. Also anytime you switch to a lrger heavier tires, the motor has to work that much harder, there more weight and rolling resistance with larger tires.
