03 4x4 QC Hemi - Electrical question
Old Feb 19, 2008 | 07:35 PM
babbabuee's Avatar
babbabuee
Default 03 4x4 QC Hemi - Electrical question
have a small problem and thought one of you super intelligent guys could help me out. here's the problem... All the power windows function and i can open and close them from the drivers side control, BUT NOT FROM THE ACTUAL DOOR. so the passengers can't roll down/up the windows. and yes of course, I checked the windows lock button. I pushed it up and down and jiggled it and still no luck on the other doors. I'm trying to think of the easiest way to fix this... i thought about just replacing the control unit from the drivers side as maybe the window lock switch is messed up or stuck. what do you guys think, and if you do think i should replace that part, where should I look for it?
thanks in advance
babba
Old Feb 19, 2008 | 07:47 PM
chadmech28's Avatar
chadmech28
Default RE: 03 4x4 QC Hemi - Electrical question
There is a main yellow power feed from the master lock to the other switches, trace it down. Make sure to check the door boot for breakage. You probally will find it rotten under the drivers sill plate, It's the solid yellow wire.
Old Feb 19, 2008 | 10:19 PM
babbabuee's Avatar
babbabuee
thanks chad, i'll take a look at it tomorrow.
Old Feb 19, 2008 | 10:34 PM
tooonuts's Avatar
tooonuts
Is this the real babbabuee? I have the same problem with my 03 Ram hemi, However it comes and goes. Maybe chad has it right. Have you had any problems with your keyfobs not working?
