p0440
Old Feb 21, 2008 | 12:00 AM
Mayfairisafunnymfer's Avatar
Mayfairisafunnymfer
Default p0440
2004 Ram RC 3.7L 64,000 miles
So I get this code p0440 when my fuel gets down to 3/8 or so. I have replaced the gas cap. No change. Besides not letting it get down that low does anyone have any suggestions. I have included some info on the code below. So another question is where is this said purge valve and charcoal canister? Is the dealer the only place to get one. Thank you in advance for your help.
A code P0440 could mean one or more of the following has happened: [ul][*]The gas cap is not installed or working properly[*]The purge solenoid has failed[*]The canister is plugged and not working properly[/ul]
Old Feb 21, 2008 | 06:20 PM
Mayfairisafunnymfer
Default RE: p0440
No suggestions?
Old Feb 22, 2008 | 01:33 PM
Mayfairisafunnymfer
Default RE: p0440
It looks like I have one hell of a problem here then.
Old Feb 22, 2008 | 05:30 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: p0440
Uh yes, I have a suggestion. Check the rubber lines to and from the charcoal canister. After a couple of years they start leaking and cause the evap code. I'm replacing mine this summer with silicone lines (autozone) as I do a lot of salt ridden winter driving, and it sucks to work on em when its cold ands covered in slush, ice, and mud. The canister should be up in the frame rails behind the drivers side.
Good Luck!!!
Old Feb 23, 2008 | 03:57 AM
Mayfairisafunnymfer
Default RE: p0440
Hey thanks I'll have to check it out.
