Cams?
Old Feb 21, 2008 | 11:47 PM
86Ram's Avatar
86Ram
Default Cams?
hey im trying to figure all this stuff out and its takin a little while but i think im getting it if someone could tell me what the biggest difference is between the KRC 210 and the Comp 268 is it would be much appreciated and a big help i know there was already another bulletin about this but it was pretty old so i wanted to make sure someone would see this because i am really confused thanks
Old Feb 22, 2008 | 12:23 AM
CRMRAM's Avatar
CRMRAM
Default RE: Cams?
Here ya go This is straight off there site.
KRC 210 Hemi
210/214-523/526 112 Excellent RV cam that requires no other engine modifications. Run's well with factory NGC controller at 18" vac from factory 19", and valvesprings. Excellent 4x4 cam for heavier Rams running 3.55/3.92 and 20" Rims. Excellent cam with headers, but not needed. Smooth idle, 35hp and 25ft/lbs. 320-330 rear wheel no head work.
I cant find the info on the comp cam.
