What size tires?? please help 2003 2wd quad cab
Old Feb 25, 2008 | 04:28 PM
trizon's Avatar
trizon
Default What size tires?? please help 2003 2wd quad cab
hey yall. just a quick qwestion. i have a 2003 dodge ram 2wd quad cab(short bed) with the 20" factory wheels. i also have a 2 inch leveling kit on the truck so the truck now sits flat and doesnt hang low in the front. was wondering whats the biggist tires i can put on the veahicle???
33x12.50x20 a good size? or could i go bigger? to a 34 or 35. or maybe a bigger metric tire???? thx alot guys
Old Feb 25, 2008 | 04:48 PM
jstmahoney's Avatar
jstmahoney
Default RE: What size tires?? please help 2003 2wd quad cab
go to tire rack and put in the make and all that then it will give u the tires that will fit on the 20" factrory rims. Let us know what you get and if you like them. I will be getting new tires somtime this year. I also have the 20" rims. dang they are expensive though, alot more than tires for my Camry or my Solara!
Old Feb 25, 2008 | 04:55 PM
trizon's Avatar
trizon
man they only offer some small tires i know i can accomadate bigger then what tire rack states. ANYONE KNOW dont forget about the 2inch leveling kit on the front.
Old Feb 25, 2008 | 05:54 PM
Heminator2's Avatar
Heminator2
I run 305/50/20 Toyo Proxes ST on mine and they look great. No rubbing and ride fantastic.
Old Feb 25, 2008 | 08:02 PM
stunta666's Avatar
stunta666
you should be able to clear atleast 33's no problem but it all depends on the rim. my truck came with the factory 33's but mines a 4x4, so if yours is levelled you should be able to go 33 minimum.
Old Feb 25, 2008 | 08:11 PM
Aladin Sane's Avatar
Aladin Sane
You need to ask Your Displacement - Tyranny and Rear that question first. The truck will look good but will slow down the road.
[IMG]local://upfiles/83825/8D2B5FFB9EDE4E75A777EAAFCA3B903D.jpg[/IMG]
Old Feb 25, 2008 | 09:49 PM
trizon's Avatar
trizon
wondering if anyone thinks i could run 35s with the 2 inch leveling kit?
