tire size
I would say that should work especially if you are using the stock 20 inch wheels, that way you are not changing the offset at all which is to your advantage when there are clearance issues. The 325'sare pretty wide but on a stock rim they aren't going to look like they would on a 10" rim or a rim with more offset to the outside. The heigth should not be an issue with the leveling kit and the body lift you should have more than enough room for a 35 inch tire. I am curious to see how it looks, so post a pic when your done.
