Scangauge II and tranny temps
Old Mar 7, 2008 | 08:29 PM
GerryG's Avatar
GerryG
Default Scangauge II and tranny temps
Who has the Scangauge II in their Hemi Rams? Do you like it? Does it have the tranny temps?
Gerry
Old Mar 7, 2008 | 08:41 PM
Hemichief's Avatar
Hemichief
Default RE: Scangauge II and tranny temps
I have a Scangauge II on my truck. I like it. It is limited because it will give you what the OBDII reads. Unfortunately it will not give you the Transmission Temp. However, you can just about pull everything else on it.
For me I find it helpful when I tow.
Old Mar 7, 2008 | 09:03 PM
GerryG's Avatar
GerryG
Thanks for the info, Hemichief.
I've been looking at an easy way to get the tranny temps when pulling a travel trailer. That's the main reason I was looking at the ScangaugeII.
Gerry
Old Mar 7, 2008 | 09:35 PM
Sobomaster's Avatar
Sobomaster
I have transmission fluid temperature on my Edge tuner.
Old Mar 7, 2008 | 10:36 PM
Hemichief's Avatar
Hemichief
Gerry
I actually got an analog tranny temp gauge and installed it on the pillar. It was a 30 minute job and I run that gauge right of my tranny. You should consider it. Good luck to you
Old Mar 10, 2008 | 07:05 PM
GerryG's Avatar
GerryG
Hemichief, maybe the analog gauge is the way to go.
Are there any do-it-yourself instructions available on the web?
