Pass side head light is out
Old Mar 9, 2008 | 09:40 AM
chriso3wj's Avatar
chriso3wj
Default Pass side head light is out
I have a 2007 1500 and the pass is out on the truck and my plow. The high beam works on both sides and the bulbs are brand new. I checked for a fuse but there is not one for the head lights, if any one has an idea shoot it my way.
Old Mar 9, 2008 | 10:58 PM
MikeHTally's Avatar
MikeHTally
Default RE: Pass side head light is out
There's gotta be a fuse, relay or breaker somewhere. I'll be dogged if I can find it in the diagram for my '03, though. Weird.
Old Mar 9, 2008 | 11:56 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Did you chase the wires for the light and look for a short? While I was crawling around under my truck the wiring looked as if it was spliced and fixed with electrical tape. I think the wiring on the Ram sucks ***. (Assembled in Mexico.)
Old Mar 11, 2008 | 08:52 PM
chriso3wj's Avatar
chriso3wj
It just don't make any sence that the only the low beam is out on both the truck and the plow. i chaced all the wires and every thing looks good, and couldn't find a fuse or a relay anywhere. next step is to test the wires and see if maybe the plug itself is bad. I let ya know and thanks for the input.
Old Mar 11, 2008 | 09:07 PM
damram1980's Avatar
damram1980
spray wd-40 on he recepticle that hooks up3 the headlight if u do this and it workd u know the plug is bad if not, fuse. if u cant see a fuse think about volt wire a lot of wires now rey on amps to melt causing replacement of a wire . just a thought
