SPARK PLUGS
Old Mar 10, 2008 | 12:42 AM
RamItOne's Avatar
RamItOne
Default RE: SPARK PLUGS
i think the gap is 40 check under the hood it should say. youre not supposed to deviate more than .008 from the mfg gap.
Old Mar 10, 2008 | 12:49 AM
mmstar23's Avatar
mmstar23
but if i just get the plugs meant for my truck all i have to do is screw them in right.....?
Old Mar 10, 2008 | 01:52 AM
RamItOne's Avatar
RamItOne
Should be, its a 4.7 right? Hemi has 16.
Old Mar 10, 2008 | 06:23 AM
VA4MEDS's Avatar
VA4MEDS
ORIGINAL: mmstar23
Check the gap on the plugs before putting them in. They are never exactly gapped properly & many plugs fit other makes/models.
Speed Safely,
AL
Old Mar 10, 2008 | 06:47 AM
MikeHTally's Avatar
MikeHTally
Make sure you blow the trash out of the area around the plugs so none of it drops into the cylinder. The back four are a challenge to get to. I think the '07s don't have plug wires, so just take the coil packs off an' go for it. The time range to change all sixteen is 1 1/2 to 3 hours.
Old Mar 10, 2008 | 10:13 AM
Toolman74's Avatar
Toolman74
Don't gap iridiums. They are ready to go.
Old Mar 10, 2008 | 10:32 PM
MikeHTally's Avatar
MikeHTally
Any plug can have the gap altered in shipping. Coupla good bumps is all it'd take.
Old Mar 11, 2008 | 12:59 AM
Toolman74's Avatar
Toolman74
They come packaged with protective sleeves so that the gap can not be altered during shipping. When adjusting gap on an iridium plug, you have to use extreme caution. They are not like gapping your regular copper champion plug. You can damage the plug if not done right.
http://www.densoiridium.com/faq.php
Old Mar 11, 2008 | 11:52 AM
mmstar23's Avatar
mmstar23
whatever, im just gonna get the plugs and they should have a 40 gap...if not ill go from there, but if theyre at 40, theyre just getting dropped in
thanks guys
