front axle fluid
Old Mar 10, 2008 | 10:54 PM
chadrules's Avatar
chadrules
Default front axle fluid
There is no DIY on this yet? How can that be? What is the volume of lube required?
Old Mar 10, 2008 | 11:43 PM
RamItOne's Avatar
RamItOne
Default RE: front axle fluid
2 or 2.5 pints. 5/8ths of an inch below the fill hole....mmmmm fill hole
PS why dont you make the DIY.
Old Mar 11, 2008 | 10:42 PM
chadrules's Avatar
chadrules
HAHAHA!!
Yeah i may just do that, i got 3000 miles to go though.
Old Mar 11, 2008 | 10:57 PM
SLCHemi's Avatar
SLCHemi
Other than the capacity, and having to deal with stearing or other components that aren't in the way out back, it's basically the same drill...undo a bunch of bolts, drain, clean, re-do a bunch of bolts and fill (unless you've got a fancy cover with a drain / fill hole like me )....
