Please help!
Old Mar 13, 2008 | 10:01 PM
Dwilson1985's Avatar
Dwilson1985
Default Please help!
Ok so...ive had my ram 2500 for about 2 weeks now, bought it used and im pullin my hair out. It has an intermittent problem where the check engine light comes on and so does a flashing red light it the lower left corner of the cluster kinda looks like a lightning bolt with inverted Parenthesis (sp?). When these lights are on the truck keeps wanting to stall at idle, it runs fine at driving RPM. ALSO im getting roughly 8.5 MPG with most of it being highway driving.....anyone have any ideas? (im car stupid and still learning so please use little words :S) any help would be throughly appreciated
Old Mar 14, 2008 | 09:06 PM
HammerZ71's Avatar
HammerZ71
Default RE: Please help!
Can't really help you without knowing what the specific code is. Hit an Autozone or other auto parts chain store, they'll put a scanner on it and give you the code, usually for free...
Old Mar 16, 2008 | 09:09 PM
Dwilson1985
I went to autozone and had the code pulled. it was P 2175 " TAC System Low Airflow". It also finally stalled on me at a stop sign. Any idea?
Old Mar 16, 2008 | 09:18 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
I'd say remove the TB and clean it good....i'd use a non-residue cleaner like electrical contact cleaner or MAF cleaner that CRC makes. I only say that because of the drive-by-wire TB...I haven't cleaned mine yet so I dunno how exposed the electric motor is. Otherwise carb or brake cleaner will work..
Old Mar 16, 2008 | 09:39 PM
Dwilson1985
Ok, ill give that a try, Any ideas as to why my gas milage is so crappy?
Old Mar 16, 2008 | 11:52 PM
SeVeReDiStOrTiOn
ORIGINAL: Dwilson1985
Since you just bought it i'd do a full tune-up...along with cleaning your throttle body that should really help your mpg. The 2500's are also pretty heavy compared to a 1500...so your mpg won't be as good.
Old Mar 17, 2008 | 12:00 AM
mmstar23's Avatar
mmstar23
ORIGINAL: SeVeReDiStOrTiOn
+1
new plugs, change all your fluids. motor oil and filter, tranny fluids and filters, differntial fluid, mayeb check your belt. id also through some fuel system cleaner in it to help a bit. i boughtmine used and ran some fuel system cleaner in the first 2 tanks and got me like 2.5 mpgs. make sure that throttle body is clean too, just be carefull around the sensor...use a q-tip around there. and use brake cleaner...not throttle boddy cleaner.
Old Mar 17, 2008 | 02:58 AM
killerbud420's Avatar
killerbud420
what is thatlightning boltlight for right after my motor blew i was rollin down the road that came on
