I'm gettng 11 mpg city. What can i do?
Old Mar 23, 2008 | 04:08 PM
De pinga!'s Avatar
De pinga!
Default I'm gettng 11 mpg city. What can i do?
I'm thinking of getting a fuel injection cleaner.. but which one should i use? Whats the best out there... ANY info on how to make my MPG better feel free to include please..im curious on what i can do.
Old Mar 23, 2008 | 04:52 PM
damram1980's Avatar
damram1980
Default RE: I'm gettng 11 mpg city. What can i do?
i thought i was gettin 12 in the city, but last time i filled uo i held the reset button 4 a couple min and i started gettin 15. i checked it with pen and paper and it was right. gunk has always been good to me,i would try taking off the air filter box and cleaning the throttle body before dumping chemicals in ur truck. my.02
Old Mar 23, 2008 | 04:54 PM
De pinga!'s Avatar
De pinga!
how would i clean that? thats that big box that syas 4.7 right? how would i clean that.. i heard i can do it but never have..
Old Mar 23, 2008 | 05:03 PM
RamItOne's Avatar
RamItOne
lol its called a plenum, your tb is right behind it. you may have a mass air sensor on the plenum that needs to be disc depending on the age of your truck, you can either just swab the front of the tb with brake cleaner or you can take off the tb and clean it well, you'll need a tb gasket.
Old Mar 23, 2008 | 05:16 PM
MikeHTally's Avatar
MikeHTally
I've been using Gunk products for a while with no complaints. I usually give him a dose when I change the oil. I may switch to Seafoam next time, though.
Old Mar 23, 2008 | 05:24 PM
LoFlyer's Avatar
LoFlyer
Not a direct answer to your question, but have you recalibrated your speedo/odo for larger tires?
Old Mar 23, 2008 | 05:33 PM
De pinga!'s Avatar
De pinga!
no i havent recaliberated anything for bigger tires but you do have a point... how would i do that? and how would i remove the box and clean it? what do i have to do...
Old Mar 23, 2008 | 05:59 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Driving habits has a lot to do with it also...try to keep it under 2000 rpms in the city when accelerating. Taking the TB off is self explanatory...even if you've never turned a wrench you should be ok. Just pop the hood and go at it...
Old Mar 23, 2008 | 08:41 PM
HammerZ71's Avatar
HammerZ71
If your tires are larger than stock, your gas mileage will calculate (both on the read out and pen & paper) not to mention your speedo will be off. You may be getting the same mileage most of the rest of us are, and not know it. Re-calibrate for the tires, then check your mpg's...
Old Mar 23, 2008 | 08:54 PM
dodgenitto's Avatar
dodgenitto
Default RE: I'm gettng 11 mpg city. What ca"n i do?
you can get the "superchip" It is an easy way to recalibrate your speedo for your tires! And also gives you more options for performance! Not too bad for the price since you can plug it into your computer and update it any time they come out with new upgrades for your truck! I would not but hyper tech!! Will not adjust speedo for 5.7L hemi's
