Detailed breakdown of service by mileage intervals
As requested by R/T some time ago. Here's a breakdown of all listed scheduled maintenance by mileage intervals as stated in the official Maintenance Logbook that comes with the truck. It is from a 2005 5.7L (HEMI) QC 4x4. This is for "Schedule B", which as noted: "MOST VEHICLES ARE OPERATED UNDER THE CONDITIONS LISTED FOR SCHEDULE B". Perhaps I'll do Schedule A sometime. I believe the book covers all models (except CDT), but YMMV...
3,000 Miles / 3 Months
-Change engine oil and engine oil filter.
-Drivetraing/Steering/Suspension Grease Fittings (if equipped)
-Check automatic transmission fluid level
-Check manual transmission fluid level
-Check coolant level, hoses, and clamps
-Inspect exhaust system
-Inspect brake hoses
-Inspect CV joints (if equipped) and front suspension components
6,000 Miles / 6 Months
-Lubricate outer tie rod ends 2500/3500 (4x4) models only
-Rotate tires
9,000 Miles / 9 Months
12,000 Miles / 12 Months
-Rotate tires
-Inspect brake linings
15,000 / 15 Months
-Inspect engine air cleaner filter, replace as necessary
-Change rear axle fluid
-Change front axle fluid (4x4)
18,000 Miles / 18 Months
-Rotate tires
21,000 Miles / 21 Months
24,000 Miles / 24 Months
-Rotate tires
27,000 Miles / 27 Months
30,000 Miles / 30 Months
-Rotate tires
-Replace spark plugs
-Check transfer case fluid level (4x4)
-Inspect engine air cleaner filter, replace if necessary
-Inspect PCV valve, replace as necessary
33,000 Miles / 33 Months
36,000 Miles / 36 Months
-Rotate tires
-Check brake linings
39,000 / 39 Months
42,000 Miles / 42 Months
-Rotate tires
45,000 Miles / 45 Months
48,000 Miles / 48 Months
-Rotate tires
51,000 Miles / 51 Months
54,000 Miles / 54 Months
-Rotate tires
57,000 Miles / 57 Months
60,000 Miles / 60 Months
-Change 6-spd manual transmission fluid 2500/3500 models only
-Drain and refill transfer case fluid (4x4)
-Drain and refill automatic transmission fluid and change main sump filter*
-Lubricate innter tie rod ends 2500/3500 (4x4) models only
-Rotate tires
-Replace spark plugs and ignition cables
-Inspect engine air cleaner filter, replace if necesary
-Inspect brake hoses and brake linings
*This applies only if the vehicle is used for frequent trailer towing, snowplowing fleet vehicle or commercial use
63,000 Miles / 63 Months
66,000 Miles / 66 Months
-Rotate tires
69,000 Miles / 69 Months
(gotta go pick my truck up from the dealer for maintenance. will finish this later today or tonight)
----------------posting this now so I don't lose it all by accident!!! please don't reply until I'm completely finished with it all. I'm still working on it!!----------------------
-Rotate tires
-Rotate tires
15,000 / 15 Months
-Rotate tires
-Rotate tires
-Rotate tires
-Rotate tires
39,000 / 39 Months
-Rotate tires
-Rotate tires
-Rotate tires
-Rotate tires
-Rotate tires
