Transmission shifting wrong after being serviced?
Old Apr 3, 2008 | 05:28 PM
Kuhns48's Avatar
Kuhns48
Default Transmission shifting wrong after being serviced?
Hey guys I need some serious help, Heres what happened today i did a service to my transmission and to the rear end i got all the right gaskets back in, cleaned up the outer perimeters, before putting the new gaskets and all back on, the right Transmission fluidand all the correctthings to do,when i finished up, i let run till it got to running temp then when to back it out of my drive the transmission does not shift right, at a dead stop you have to get the rpms up for it to go intogear and when i slow down it doesnt down shift i have to do it maually.
Old Apr 3, 2008 | 05:40 PM
dreman's Avatar
dreman
Default RE: Transmission shifting wrong after being serviced?
I'm assuming you did check the trans fluid level after it warmed up?
Old Apr 3, 2008 | 05:47 PM
Kuhns48's Avatar
Kuhns48
Well of course! i even went to limit of mearsuring how much trans fluid came out so i knew how much to put back in
Old Apr 3, 2008 | 06:01 PM
dreman's Avatar
dreman
Just thought I'd ask the obvious and get it out of the way!
Other than that I don't know enough about these transmissions yet to make an educated guess. I haven't been into the one in our truck yet.
