Check engine light - code P0524 low oil pressure on 07 Ram 1500 Hemi
Old Mar 30, 2012 | 03:32 PM
  #21
DodgeCares's Avatar
DodgeCares
Originally Posted by olemech
took my 2008 4x4 1500, 5.7 hemi for code P0524 there is a TSB on this truck, thay had to flash my computer to get light to stay out. thay also said sometime you have to replace sending unit, thay have also had to replace wiring harnes to sending unit, gets pinched by untake. TSB 18.003.08 this is for 2007-08 with build date of 08-07 and before.
Below is the TSB.
NUMBER: 18-003-08
GROUP: Vehicle Performance
DATE: January 19, 2008
SUBJECT:
Flash: MIL Illumination Due To Diagnostic Trouble Code P0524 - Engine Oil Pressure Too
Low
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS:
**2007** - 2008 (DR/DH/DC/D1) Ram Truck (1500/2500/3500)
**2007** - 2008 (HB / HG) Durango / Aspen
**2007** - 2008 (LX) 300 / Magnum / Charger
**2007 (LE) 300C/300 Touring (International Markets)**
**2007 (L2) 300 (China)**
**2007** - 2008 (WK) Grand Cherokee
**2007 - 2008 (WH) Grand Cherokee (International Markets)**
**2007** - 2008 (XK) Commander
**2007 - 2008 (XH) Commander (International Markets)**
NUMBER: 18-003-08
NOTE: This bulletin applies to the above listed vehicles equipped with a 5.7L engine
with MDS (sales code EZB) built before the following dates:
• (HB/HG) built before August 15, 2007 (MDH 0814XX)
• (LX) built before September 14, 2007 (MDH 0914XX)
• (DR) built before August 16, 2007 (MDH 0816XX)
• **(WK/WH/XK/XH) built before January 8, 2008 (MDH 0108XX)**
SYMPTOM/CONDITION:
The vehicle operator may experience a Malfunction Indicator Lamp (MIL) illumination due
to the following Diagnostic Trouble Code (DTC):
· P0524 - Engine Oil Pressure Too Low
DIAGNOSIS:
Using a Scan Tool (StarSCAN®) with the appropriate Diagnostic Procedures available in
TechCONNECT, verify all engine systems are functioning as designed. If other DTC's are
present record them on the repair order and repair as necessary before proceeding further
with this bulletin.
Old Aug 28, 2012 | 12:06 PM
  #22
DaveCinHutto's Avatar
DaveCinHutto
For $104 they well fix it!( Dodge dealer) Really? A factory defect and then charge me $104 due to firmware being incorrect. This code only happens when it is idling. Warm fuzzies are not being generated.
Originally Posted by DodgeCares
Below is the TSB.
NUMBER: 18-003-08
SUBJECT:
Low
OVERVIEW:
MODELS:
NUMBER: 18-003-08
SYMPTOM/CONDITION:
DIAGNOSIS:
with this bulletin.
Old Aug 29, 2012 | 08:35 AM
  #23
olemech's Avatar
olemech
Default P0524
my local dealer fixed mine for free, they used tsb which was about my problem and put it on laptop and retune it so light would stay out.
Old Aug 31, 2012 | 10:43 PM
  #24
chiefjack's Avatar
chiefjack
My 2008 Ram 1500 4X4 with a Hemi just had the check engine light come on and I took it to our local dealer to get it checked. After sitting for 4 days, the Service Advisor called me and told me the code was P0524, and the oil pressure sending unit was bad. $314.35 later, I had a new oil pressure sending unit and was on my way.
No mention of a TSB and no mention of any of the problems with the Hemi as discussed here. Next week, I will be making a trip back to the dealer to discuss this issue in more depth.
Old Sep 4, 2012 | 11:41 AM
  #25
DodgeCares's Avatar
DodgeCares
Jack,
Please keep in mind that the TSB is not the only resolution to the P0524 code but is intended as a troubleshooting suggestion. I would certainly ask the dealer about it though.
Old Sep 5, 2012 | 02:36 PM
  #26
DaveCinHutto
Doesn't the oil pressure gauge work off the sending unit? My gauge shows good pressure at idle and you can see it move when the RPMs increase.
Old May 31, 2018 | 12:29 AM
  #27
Kendrik Castro's Avatar
Kendrik Castro
Default Same
Originally Posted by magnum35xr
Yellowram, I am having the exact same issue with my 2007 quad cab Hemi 4x4. When idling, my oil pressure gauge does the same thing as yours was doing, the check engine light came on and autozone gave me the code reading P0524. The gauge drops just below half mark by about 1/8th inch, when driving its just above and in the normal range I am used to seeing it.
What did you end up having to do or get done by a dealer to get it fixed?
I found the oil pressure sensor on the block and could easily replace it, however I didn't want to waste 50$ if it might be something else.
Thanks for any help you can suggest.
-Magnum35XR
this exact thing happened to me, I bought the switch from autozone an replaced it. Check engine light hasn’t not gone away yet an it still reads a lil below half when it’s idling, then i drive an goes back up
Old Aug 2, 2019 | 08:11 PM
  #28
Michael D Niebruegge's Avatar
Default Low oil presure
Is there a way to fool the computer to think you have good oil presure all the time ?
Old Mar 21, 2020 | 10:30 PM
  #29
deere-and-dodges's Avatar
deere-and-dodges
Default small note
a few people on here have stated not having a code reader and going to autozone. i may have thought it was common knowledge but on most dodge vehicles if you cycle the key 3 times the dash will show you the codes on the odometer display.
Old Jan 8, 2025 | 09:16 PM
  #30
Speidelm's Avatar
Speidelm
Originally Posted by The BIG STEAK
Hey People, Anyone ever get the check engine light code P0524 for low oil pressure? I have had it 3 times now since I got the truck new almost a year ago. It has 20000km, the oil level is good, oil just changed and the gauge on the dash reads a little over the half way point. When the CEL comes on, the truck has been running for about half an hour (fully warmed up) and idling in gear at the stop light. The freeze frame data on the code reader shows normal engine temp, RPM at about 650 and no other codes in memory. The truck engine management stays in closed loop mode too. Since I have a code reader, I just reset the light myself. Should I be overly concerned? Should I bring it to the dealer so that they can address this? Truck is running fineotherwise. ANY thoughts???
Thanks
STEAK
do you have a slow leak aswell?
