Are these stereo wires?
Old Apr 6, 2008 | 04:25 PM
Rodie40's Avatar
Rodie40
Default Are these stereo wires?
This picture was taken with the pass side kick panel removed on a 2007 ram. Im going to add an amp under the pass seat and need to connect to the speaker wires. I was going to come from the stereo, but saw these next to the antenna plug and thought they might be speaker wires? Would be easier to cut into the wires here if anyone knows I appreciate it. Thanks,
Dan
[IMG]local://upfiles/86236/993BE02F62634CA5BD966D0BBC60347B.jpg[/IMG]
Old Apr 6, 2008 | 08:02 PM
MikeHTally's Avatar
MikeHTally
Default RE: Are these stereo wires?
Could be, but to be absolutely sure, I'd compare EVERY wire color in that harness to the one on the HU. The only ones missing may be the power leads, but I'd hope the driver's side leads are evident. Remember, there are NO common grounds in today's audio systems.
Old Apr 6, 2008 | 08:54 PM
daytona1680's Avatar
daytona1680
you could also pull off your door panel then pop out the speakers to see what color the wires are.
