Tube step question?
Old Apr 10, 2008 | 10:32 AM
slamdry's Avatar
slamdry
Default Tube step question?
Does anyone know of a set of tube steps that are easy to install but dont use the body mounts as a mounting point??
I had purchased a set of westins for my 02 ram quad cab, but my body mount bolts dont want to come out, i used a air impact, soaked them in seafoam, and put a breaker bar on them and when i felt it starting to twist and not loosen i gave up so i didnt snap it. And i dont want to heat them becuse i dont want to burn the rubber cusion up either.
any help would be appreciated.
Old Apr 10, 2008 | 02:21 PM
Martin460's Avatar
Martin460
Default RE: Tube step question?
Maybe Back Country is your choice:
http://www.buyautotruckaccessories.c...ry-tube-steps/
Old Apr 10, 2008 | 04:56 PM
stunta666's Avatar
stunta666
Before you return the westins, try to unscrew the body mount by loosening the other way as in turning it right. I got an 06 and i went through the same thing and almost gave up until i turned the bolt the other way. Normally it's right tight left loose but for the body bolts its left tight right loose. Good luck.
Old Apr 10, 2008 | 08:31 PM
slamdry's Avatar
slamdry
ahh good call, one of my techs is going to give it a whirl for me tomorrow, so hopefully it works out!
Old Apr 10, 2008 | 10:19 PM
HEMI07's Avatar
HEMI07
the factory mopar tube steps dont bolt to the body mounts
Old Apr 11, 2008 | 06:52 PM
slamdry's Avatar
slamdry
actaulyl im all set now, oine of my techs at work got the brackets on for me so i am good to go!!! just need the rain to stop so i can put the tubes on!!
