window issues
Old Apr 10, 2008 | 08:36 PM
CaymanRam's Avatar
CaymanRam
Default window issues
Ok, i have a 2004 4dr Ram 1500. I've replaced all the window switches, and they are still not rolling down. The only way that the windows go down is from the main switch. NOw if i am putting the windows down with the main switch(let's say the front passenger) with the main (drivers) switch, it will go down, but as soon as i press the switch on the passenger side, the window stops, and then keeps going once i let go of the passenger side switch.
Any ideas? please letme know asap.
Thanks
webster.me@gmail.com
Mike
Old Apr 10, 2008 | 09:36 PM
SeMiGoD's Avatar
SeMiGoD
Default RE: window issues
Ground split or power wire dumped after the main wire. These things, (ford, chev and dodge), are wired REDUNDANT. A million wires run that arent needed for simple jobs. Im far from a wiring guru and wish i could give you more than that. Start testing the wires coming out from the main switch as thats where the other switches get their power from. Good luck and wish i could be of more help.
Old Apr 14, 2008 | 06:09 AM
Sphinx boostin's Avatar
Sphinx boostin
i have dang near the same prob but when its warm out i no longer have the prob it works as advertised
