Tranny stuck in 2nd
Old Apr 11, 2008 | 01:45 AM
da92gs87's Avatar
da92gs87
Default Tranny stuck in 2nd
Well today i put in my Jet 180 t-stat (btw, thanks Duane from 3rd strike) and decided to give it a drive to see the temp difference. As I was comming towards a light that was turning yellow, i stepped on it to beat the light... well, it went to down shift and then stayed at 3000 rpms in 2nd gear for about 2-3 seconds, then started to get up and go. After that had happened, when it would go into 3rd the rpms would just climb like i was in neutral and would not go at all... so i maunally put it into 2nd and started my drive back home... along the way i would throw it back in to D and again rpms would climb and i wouldnt go any where... now when i stop it doesnt down shift into 1st at all, even if i manually shift it down into 1st.
there is 114K on her and no warrenty left... would anyone be able to point me in the right direction? also, i havent checked the DTC's yet because i am just to pissed off right now.
[/align]
Old Apr 11, 2008 | 09:34 AM
abarmby's Avatar
abarmby
Default RE: Tranny stuck in 2nd
Sounds like you've discovered the weak 2nd prime problem first hand????
I do hope you haven't.
There's a known problem I believe, whereby when you Kickdown into 2nd prime from 3rd at speed,the auto box grenades.
A lot of people aware of this, tend to shift manually into 2nd after a pause, then floor it and change up on the column.
Read off the codes and post up.
In the meantime, keep your fingers crossed.
Al.
Old Apr 11, 2008 | 10:05 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Same exact thing happened to me. It ended up being the tranny solenoid locking up. Good news for me was that it happened under warranty so I can't give you a cost on the repair. I'll try to find my post about it and link it so you can see.
I found the link with the code that I was getting.
https://dodgeforum.com/m_813772/tm.htm
Old Apr 11, 2008 | 04:10 PM
da92gs87's Avatar
da92gs87
Well I found the code its bringing up, P0700. I looked it up in my Haynes manual and it says Transmition Control System (MIL Request)... so would my TCM be taking a dump? and what is this MIL request crap?
BTW, i was also crossing my fingers on the auto box deal[X(]
Old Apr 12, 2008 | 12:16 AM
oefootball_70's Avatar
oefootball_70
well hell i just got the same one.
