Performance questions
Old Apr 16, 2008 | 12:04 AM
02RedRam1500's Avatar
02RedRam1500
Default Performance questions
looking to do some minor upgrades hoping for better gas mileage. Truck is an 02 ramm 1500 quad cab 2wd 5.9 gas motor w the factory 20's. Here come the questions.
Which spark plugs are best?
Which wires are the best?
Is it worth doing a throttle body spacer?
Which intake would be best?
Flowmaster or Gibson cat back?
Any other mods I should look into instead?
Which oil and filter?
Old Apr 16, 2008 | 12:34 AM
SDPOWERWAGON's Avatar
SDPOWERWAGON
Default RE: Performance questions
Is it worth doing a throttle body spacer? YES !
Which intake would be best?AEM , MOPAR , those 2 tubes are round , no bend
Flowmaster or Gibson cat back? Your choice
Any other mods I should look too ?TUNER Superchip , Bully Dog , Edge
Which oil and filter?Dodge filter , any good oil frequently changed
I have all this and it's a lot of fun + better mpg
Have funand enjoy [sm=icon_cheers.gif]
Old Apr 16, 2008 | 01:06 AM
02RedRam1500
Thank you for the help even with a gas engine I can go with the bully dog tuner
Old Apr 16, 2008 | 01:40 AM
Rot Weiss Essen's Avatar
Rot Weiss Essen
Get rid of the factory 20's and get some lighter weight 17's or 18's and you will get better milage and more performance.
Old Apr 16, 2008 | 07:35 AM
HammerZ71's Avatar
HammerZ71
Good tune up using synthetics will help. I agree with ditching the factory 20's in favor of some light weight aluminum 17's, then you should look into a Cat-back exhaust, CAI or at least a premium drop-in and tuner...
Old Apr 16, 2008 | 02:42 PM
hardtufind's Avatar
hardtufind
I have a 2002 Dodge Ram 1500 Quad Cab 2wd 5.9L 20" stock tires
I'm also looking to improve gas milage and performace.
I use Mobil 1 5W-30, and a Mobil 1 filter.
I'm planning on using Bosch Platinum Ir Fusion spark plugs, 40 Series Delta Flow Flowmaster
We'll see how it works.
Old Apr 16, 2008 | 03:55 PM
dreman's Avatar
dreman
ORIGINAL: Rot Weiss Essen
Get rid of the factory 20's and get some lighter weight 17's or 18's and you will get better milage and more performance. [sm=exactly.gif]
How much do the factory 20's weigh? I've looked at Centerline forged 20's, and they claim from 24-28 lbs per wheel.
Old Apr 16, 2008 | 08:54 PM
Rot Weiss Essen
Ok, you asked for it, are you sitting down? The factory 20x9 chromes come in at a whopping 42 lbs, WHOA, I know the tire dealer always told me to go with 17's or 18's and now I REALLY know why! And people wonder why they wear out their suspension parts with these heavy 20's? Unsprung weight it is a KILLER.
Old Apr 17, 2008 | 10:33 AM
dreman's Avatar
dreman
So how much do 17's or 18's weigh? I know Centerline brags on how light their wheels are because they are forged instead of cast, but how much does a cast 17 or 18 weigh? ANd won't the tires have to weigh at least a little more to make up the difference in height?
Old Apr 17, 2008 | 07:35 PM
hemi_thing's Avatar
hemi_thing
Had a 1996 Doge Ram 1500, with 5.9L I don't know the differences between your and mine but I went with-
1. Bosch Plugs second most expensive
2. Summit Wires
3. No throttle body
4. AEM air intake system
5. No exhuast just y pipe with 5x24 tips (sounds great)
6. Jet Stage two plug in/and a cam to add a little power with a lope
7. fram oil filter with valvoline 10w-30
hope this helps
