Torsion bars
Old Apr 21, 2008 | 01:53 PM
mmstar23's Avatar
mmstar23
Default RE: Torsion bars
im pretty sure the torsion bar is only for the 4x4. if you want that little bit of lift in the front i think your best bet is a 1" coil spring spacer. i have a 2wd too and i have the 2.5" spacer.
Old Apr 21, 2008 | 03:03 PM
HammerZ71's Avatar
HammerZ71
MM is correct. I just assumed you had a 4x4 when you were talking t-bar crank. T-bars are a 4x4 only thing. You have coil overs. No freebie lift for you. You need an inexpensive set of coil spacers, I think I've seen 1.5" ones...
Old Nov 21, 2012 | 06:39 PM
Disko Superfly's Avatar
Disko Superfly
Default coil overs?
I recently purchased a '06 Ram with 5.7 hemi quad cab 4x4. I must have spent atleast two hours under the truck looking for my torsion bars, but couldn't find them. I have coil overs. Was it an option or something?
BTW, sorry for resurrecting such an old thread.
Thank you.
Old Nov 22, 2012 | 07:34 PM
Suckingas03's Avatar
Suckingas03
No Disko, 05 was the last year to have torsion bars. They have coil overs in the 06 and newer rams.
Old Nov 22, 2012 | 08:40 PM
Vader's Avatar
Vader
Does anyone know the stock distance from the top of the tire to the fender.
Trying to find out how much difference I got after new keys installed.
I forgot to measure before switching keys
