BRAKES & THROTTLE BODY CLEANING
Old Apr 22, 2008 | 02:01 PM
TEN THIRTY TWO's Avatar
TEN THIRTY TWO
Default BRAKES & THROTTLE BODY CLEANING
Just wondering how to clean my throttle body.
Also my driverside rear brake is sticking. I notices the other day i could smell burnt brakes and the rotor was realy hot. It doesn't happen all the time just once in a while. I don't know much about brakes so what do you think.
thanks
Old Apr 22, 2008 | 02:05 PM
TEN THIRTY TWO
Default RE: BRAKES & THROTTLE BODY CLEANING
Just found the link for the TB cleaning.
still need some help with the brakes
Old Apr 22, 2008 | 02:55 PM
MikeHTally's Avatar
MikeHTally
Sounds like a sticking caliper. Get it looked at before it ruins the rotor, rotors ain't cheap!
Old Apr 22, 2008 | 10:15 PM
rtmtrrdr's Avatar
rtmtrrdr
whats the link to cleaning your throttle body?.if you wouldn't mind posting it
Old Apr 22, 2008 | 11:10 PM
StevenMoffettKY's Avatar
StevenMoffettKY
https://dodgeforum.com/m_1050644/tm.htm
Old Apr 23, 2008 | 01:24 AM
sa1765's Avatar
sa1765
pull that caliper off, there are rods that it slides back and forth on...they should be well lubed, ifthey are, make sure the caliper can slide smoothly over them. i've never had the calipers off of my truck, just speaking from experience on my wife's piece of **** olds., i'm assuming these are about the same....if not, i guess i just wasted some of your time. if i did, just have another drink and enjoy the nice weather.
Old Apr 23, 2008 | 01:59 AM
RamItOne's Avatar
RamItOne
if you take your brakes apart you'll want to have a c clamp to push the piston back in. Otherwise its a pita to get em back on the rotor.
Oh that and dont forget a hammer to knock the calipers off
