MY mpg's.
Old Apr 27, 2008 | 02:58 PM
Rich11's Avatar
Rich11
Default MY mpg's.
My 03 1500 4.7L only gets 12 mpgs highway. When I am cruising at 45 - 55 mph, When I hit the accelerator, my truck will not move until I hit the accelerator enough to kick in the overdrive. So basically I can only accelerate using overdrive. What can this be? I changed the plugs and the fuel filter. Took the air box off and drove like that... nothing.. No codes come up either.
Old Apr 27, 2008 | 03:07 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default RE: MY mpg's.
Could be the torque converter...that would explain the bad mileage also. Check your tranny fluid and make sure it's at the proper level..
Old Apr 27, 2008 | 03:34 PM
Rich11's Avatar
Rich11
OK, will do. I'm not that good with these things, so can you explain the function of the torque converter (in a nut shell) so I know.
Old Apr 27, 2008 | 07:32 PM
deerjunkie's Avatar
deerjunkie
It could also be your cats. I have seen them get clogged and really takes away the power.
Old Apr 28, 2008 | 08:01 AM
Rich11's Avatar
Rich11
thanks a lot. Would the cats being clogged throw a code?
