17's on my ram ???
Old Apr 28, 2008 | 12:05 AM
meangreen383's Avatar
meangreen383
Default 17's on my ram ???
i had a question my 2wdram came with factory 20s and i was looking to put 17s with 35' tires and a 6' lift will the 17s fit or will i have brake clearance(etc)issues.
Old Apr 28, 2008 | 12:23 AM
oefootball_70's Avatar
oefootball_70
Default RE: 17's on my ram ???
No issues with 17 inch wheels. come stock with them.
Old Apr 28, 2008 | 01:13 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
on another note, if you wanna put 16's on there...you will need to shave calipers down. someone i know with an 03 put 16" rims on back for purpose of mounting slicks...and he had to shave like an 1/8 inch off of the calipers.
Old Apr 28, 2008 | 03:10 AM
locked up's Avatar
locked up
I had factory 20s and factory 17s fit on mine.
As far as fitting with the lift ... I don't know. I was actually tryingto figure out if factory 17s with work with the CST spindle lifts but I can't seem to get a solid number on what the backspacing is on a factory 17.
Old Apr 28, 2008 | 09:34 AM
omeganiner's Avatar
omeganiner
just took off my 20's and put 17" moto metal rims with 33's tire. everything worked out good
Old Apr 28, 2008 | 09:49 AM
04 HEMI 04's Avatar
04 HEMI 04
i have factory 17 inch rims look for my sig. thats is lowest rim size that will fit on dogde rams.
Old Apr 28, 2008 | 10:49 AM
CarGuyOhio's Avatar
CarGuyOhio
I also went from 20s to 17s, no issues.
With a 6" lift you could go 37s, so 35s will fit without an issue. You could actually fit 35s with a leveling kit.
Old Apr 28, 2008 | 06:28 PM
SWOS Chief's Avatar
SWOS Chief
Other than the 2wd part you are talking about my truck. No problems here, look at my album if you want to see it.
Old Apr 28, 2008 | 10:40 PM
Stroker's Avatar
Stroker
I have some factory 17 I am hoping to get rid of in about a month if your interested. I'm going to 20's Might entertain a trade
Old Apr 28, 2008 | 10:42 PM
CarGuyOhio's Avatar
CarGuyOhio
Did not notice you had a 2wd, I withdraw my comments, do not know enough about them.
