Upper and lower ball joints
Old May 5, 2008 | 08:38 AM
vinman966's Avatar
vinman966
Default RE: Upper and lower ball joints
ORIGINAL: hometheaterman
If the lowers have rivets holding them in you don't press them out. You have to cut the rivets then they just come out. The press in ones usually don't have rivets on them. Atleast none that I've seen. Do these trucks have rivets and press in? I wouldn't think they would be like that but maybe they are. The Chevy Caprice I have that I just did I cut the rivets off and it came right out. Then the lower ones were pressed in and I used a press to press them out.
No rivets on the lowers, just pressed them out. The new ones have a clip that holds them in although with the amount of force it took to press them in, I can't see the need for the clip.
Took like 5 hours to do the drivers side after having to modify the cup that is used with the press to fit around the ball joint properly. only took like an hour and a half to do the passenger side on Sunday. Front end seems tighter but still makes a ratteling noise.
All I know is that I've saved a ton of money doing it myself and I even threw on some new pads.
Old May 5, 2008 | 09:02 AM
hawkster2's Avatar
hawkster2
Get moog ball joints,they are the best, or if you don't get moog make sure the new ball joints that you get have a grease fitting. As for putting them in, the lower need to be hammer out and a special tool is needed to press the new ones in. It will take some time, but the money you will save will be well worth it.
Old May 5, 2008 | 12:49 PM
vinman966's Avatar
vinman966
ORIGINAL: hawkster2
Another tip as far as hammering them out...most auto parts stores will rent you a ball joint press which will both press the lower one out and press the new one back in. The pickle fork that will separate the lower may seem to be too thin but if you just tilt the steering knuckle until the fork is tight, then a couple whacks with a hammer will pop it right out. Good luck to anyone who wants to save about $600.00 per side!
Old May 5, 2008 | 05:51 PM
mmstar23's Avatar
mmstar23
ordered 1 upper and it'll be here wednesday and will be installed saturday
Old May 5, 2008 | 10:17 PM
vinman966's Avatar
vinman966
Did you get it off of Ebay?
You'll probably be surprised how much heavier the replacement control arm is.
I bet the whole job doesn't take you more than like 45 minutes.
Old May 5, 2008 | 11:39 PM
mmstar23's Avatar
mmstar23
ya i got it off ebay. thanks man. i talked to my mechanic and he said you normally replace both sides when you do one. he said all the boots are ripped on them, but the joint is fine and i dont have to worry about it. he just said replace the driverside upper, which i knew. but ill probally eventually do the other upper just to be safe. and hell, i may even decide to do the lowers since i can get them for like $50 for the lower set. just takes more work.
so the new one im getting will bea lot heavier than the stock one?
Old May 6, 2008 | 04:40 PM
vinman966's Avatar
vinman966
Mine is just a 2WD 1500 and I'd say the new control arm with the ball joint was at least 2x as heavy as the original.
Old May 6, 2008 | 09:56 PM
mmstar23's Avatar
mmstar23
i have the 2wd too. that good that it more heavy duty, considering after my leveling kit the control arm is pretty close to the shock bucket. atleast now if it hits i dont have to worry about bending it.
Old May 9, 2008 | 01:43 AM
mmstar23's Avatar
mmstar23
got the control arm today and brought it to work to grease that baby up. its a hell of a lot heavier duty than stock. anyone lookig for new ones i recomend ebay!
Old May 9, 2008 | 08:08 AM
vinman966's Avatar
vinman966
Yes I agree. Macautoparts is the real deal on Ebay for car and truck parts.
